Pro Touring Todays performance with classic style
  #31
Old Oct 21st, 09, 7:58 PM
66promalibu 66promalibu is offline
Tyler
Default Re: SC&C/ SPC install questions...
I'm installing the ball joints on my SPC upper arms and the bolt holes are not lining up well between the ball joint and the arm. Has anyone had this experience? Ball joints are stock replacements from NAPA for my 66. Should I try another brand?
  #32
Old Oct 21st, 09, 8:21 PM
Rich-L79 Rich-L79 is online now
Moderator
Rich
You've either got the wrong upper arms or the wrong ball joints. Post a photo.
NCOA member #220
ACES member #1670
Team Chevelle #998
1965 Malibu SS L79 Restoration Page
1965 Two-Door Wagon Project Progress Page
Rich Cummings
  #33
Old Oct 21st, 09, 10:36 PM
Tyler
I can try get a good photo. It might be difficult to capture. The holes are very close but not close enough to get four bolts in. I'll try get a picture tonight.
  #34
Old Oct 22nd, 09, 1:08 AM
Tyler
http://i849.photobucket.com/albums/a...a/IMGP0410.jpg
http://i849.photobucket.com/albums/a...a/IMGP0409.jpg
I think the issue is clearly visible. Also shows the part number of the ball joint.
  #35
Old Oct 22nd, 09, 11:07 AM
claytonisbob claytonisbob is offline
Clayton
Do both of the ball joints line up the same? Those don't look like Moog ball joints, maybe the joints are wrong?
Take a caliper and measure the hole spacing for each pair of holes on the arms and ball joints and see if its the same front to back.
  #36
Old Oct 22nd, 09, 12:29 PM
Tyler
Yes. Both joints are the same. Also both arms are the same too. These are Napa "premium", apparently made by Spicer. I think I'll try get my hands on a different brand, maybe I can find some Moog joints.
  #37
Old Oct 22nd, 09, 1:13 PM
pritchard1970 pritchard1970 is offline
Jim
I am running a moog part...I will get the number for you, mine fit perfectly in the SPC arm
http://picasaweb.google.com/threaded...36407180311746
  #38
Old Oct 22nd, 09, 8:51 PM
Tyler
I tried the Moog part at the auto parts store today. No difference.
  #39
Old Oct 24th, 09, 1:30 AM
Roadbuster Roadbuster is offline
Jon
I found the same issue with my moog joints. Marc sent me the specs on the hole pattern and the arm was spot on. The ball joints were off. A couple of minutes with a small rounded file and it fit perfect. Afterward, the bolts when inserted through both holes are perpendicular to the mating service before tightening.
The next size up in the ball joint has a much larger hole pattern and no part of the holes would line up.
Jon
Jon U.
1968 GTO - SC&C's Street Comp AFX suspension, Forgeline SO3 wheels from Prodigy Customs and Sparco seats from Motor Sport Seats
Its not a Chevelle but a close cousin
  #40
Old Oct 24th, 09, 1:33 PM
Jim
Good Morning All,
I just installed a SPC set upper and lower in my 70 wagon and no cutting or grinding was required. Also, just looking at some of the post cutting pics, are you boys worried about structural strength at all? I did run a Fat Man 2" drop spindle that is Tall for geometry correction, if that has anything to do with it. Just my experience, I listed my pics below
http://picasaweb.google.com/threaded...36390632653986
http://picasaweb.google.com/threaded...36398338238498
http://picasaweb.google.com/threaded...36409135478898
  #41
Old Oct 24th, 09, 1:37 PM
Jim
About that ball joint question, I had no problems with mine, I ran a Carquest part #K5208...It is a moog part and is made in the USA....Hope it helps
  #42
Old Oct 25th, 09, 3:27 PM
Tyler
To make the ball joints fit the arm I would have to remove material from the arm next to the ball joint opening. There isn't a lot of material there. It looks to me like I'm out about a 1/16th on the holes. It doesn't seem right that I should have to oval the holes that much to make the ball joints fit.
  #43
Old Nov 7th, 09, 12:55 PM
jkratty jkratty is offline
Jason
Guys,
When removing/installing the upper control arms on the driver's side, do you have to remove the steering shaft first? I am in the process and it appears you have to do this. If so, what is the easiest way to do this, i.e. at the u-joint or rag joint? (hope it's not the rag joint because one of the bolts is absolutely frozen solid and will not loosen).
Thanks!
