Performance Our High Performance area
  #91
Old Nov 5th, 09, 7:47 AM
69bu 69bu is offline
Rich
Default Re: 10/30 track results for the 509.
Keep me posted. I wouldn't mind getting in a few runs before the end of the year. The day after Thanksgiving is usually pretty slow.
1969 Chevelle Malibu
408 big block / th350 / 4.11 powertrax 10 bolt
12.062@113.15 on BFG drag radials
So close yet so far!
A.C.E.S. # 7037
http://www.chevelles.com/showroom/da...dium/MCC01.jpg http://www.chevelles.com/showroom/da...C_Show_015.jpg
  #92
Old Nov 5th, 09, 8:12 AM
69-CHVL 69-CHVL is online now
I lined-up at 6pm, and had 3 runs in by 6:52. Then all the oil-downs started. Those rotary wonders started getting there and having the usual breakdowns.
VINCE G.
69 CHEVELLE SS
509/AFR305/XR286/5SPD/3.90
  #93
Old Nov 5th, 09, 12:46 PM
grpweld grpweld is offline
Originally Posted by JIM View Post
The bottom of your graph is a time scale. You know exactly what your 1/8 mile time was. Find that on the graph and go straight up to see what gear you were in. Edit the logfile as well to get rid of the extra time after the run. That way you will have better resolution for the part of the graph you want to see. Make the whole file 15 seconds long instead of 1.5 minutes.
So how do you edit the log file, this would really help me also
65 malibu ss
400 sbc
jerico
9" strange 4.56
6pt roll cage
mini tubb
10.5"WX28 et drag
11.45>1 street gas, 94 oct.@ track
6.86 @ 99.6 mph
10.83 @126
  #94
Old Nov 6th, 09, 2:33 PM
Do you edit it in log works 3 ??
65 malibu ss
400 sbc
jerico
9" strange 4.56
6pt roll cage
mini tubb
10.5"WX28 et drag
6.86 @ 99.6 mph
10.83 @126
  #95
Old Nov 6th, 09, 10:39 PM
JIM JIM is offline
Jim
Sorry for the late reply. Didn't know you had asked a question.
Yes, in Logworks 3. You can do it 2 ways.
1) when you are viewing the chart, top of screen, click on tools, then selection tool. Then highlight the section you want to see, top of screen hit edit/copy, then edit/paste as new session.
or
2) when you are viewing the chart, top of screen, select the little (+) maginfier glass, then put the mouse over the time scale below and keep clicking until you have stretched out the time scale the way you want it.
If you need screen shots, let me know.
Jim
My 70 Chevelle
454+.030"
TKO-600 5-speed
Best ET 11.57 @ 121 Mph
  #96
Old Nov 7th, 09, 2:50 PM
ratss454 ratss454 is offline
brad
i hate those damn rotorys!!
i agree that the next step you should take is a good test drive, or another trip to the track and check the plugs. you are at wot longer and the engine is under a greater load in 4th. you may be lean because of the jet size and or float level, also the high speed air bleeds may need a tune.you may have to adjust to the fat side in 1st and 2nd to land right in 3rd and 4th. you are still dealing with limitations of a carbs fixed orfices.
my car has always trapped better when i 60' under 1.7. i am using the stock 3/8" pick and -6 an line to a dead head reg.
sounds like you have a killer combo, i bet it is a blast on the street.
good luck with your tuning.
1972 camaro, 3530lbs with driver
468ci, 049's, 294s, vic jr, 850 holley
th-350, tci streetfighter, 3.42's, 275/60 mickey t's
11.06 @ 122mph
  #97
Old Nov 7th, 09, 3:00 PM
Wow Jim that is so cool My charts actually make sence now
Thank You, George
65 malibu ss
400 sbc
jerico
9" strange 4.56
6pt roll cage
mini tubb
10.5"WX28 et drag
6.86 @ 99.6 mph
10.83 @126
  #98
Old Nov 7th, 09, 5:02 PM
JIM JIM is offline
Jim
Thank You, George
Glad it worked out for you.
Jim
My 70 Chevelle
454+.030"
TKO-600 5-speed
