Distributor won't drop in....
3.3K views 17 replies 9 participants last post by  JC396
Changed my Torker II for a Weiand Street Warrior intake.
My Summit Distributor lacks about 1/8 inch before seating...bout the thickness of the distributor gasket. It seated fine on the old intake.
In and out several times but no better...
What could this be?
Help
#13 ·
Could be a difference in the surface heights between the 2 intakes for the dizzy.You may need these:
Distributor shims from Jegs:
part #'s 555-40082
720-6059
720-26150
#15 ·
I have an old distributor that I tore apart and machined the end to fit in a drill for priming. I'll try that first to move the pump shaft, or you could cheat and put steady pressure down on the dist (not alot), and have somebody bump the key and it should drop right into place. I would try both of these ideas before I bought any shims..
#16 ·
I had same problem when I went from Torker 2 to a wiend stealth. Bout a 1/16 difference. I just used a second gasket. Have'nt had a problem yet. Not great machine work I guess.
#17 ·
IF the distributor is actually bottomed on the pump shaft ,it's not a good idea to use the gaskets to lift it.
Those gaskets are compressible and can cause the distributor shaft to jam the oil pump driven gear to be forced down in the pump ,dragging on the plate.
Find/make a solid spacer (or the metal shims above) that'll hold the distributor up above the 1/8" or so that your seeing.
You want some clearance so it's not bottoming on the pump drive shaft.
This is assuming that it is a difference in the 2 manifolds and not just the gear hanging on the pump drive shaft.
#18 ·
I found some shims locally (Moroso). Had to use .180 before the distributor would seat. I had it in and out about 47 times it seems but thta's what it took. I put the clamp on on it semi-tight and turned the enging slowly with a pull bar and didn't hear anything bust or pop so I guess I'm ok...I'll know when I crank it and have oil pressure etc. The pump shaft is a hardened Melling shaft that does with my pump so it's not like the nylon collar type on a stock pump/shaft.
Fun stuff. (sarcasim)
