I know that this type of thing gets old after a while, BUT would someone PLEASE simulate this combo and post the results using these 2 cams . Courious to see what it's SUPPOSED to do. Thank you so much. Dan
1. CC XS274S(12-677-4) 236/242@.50 .501/.510 lift
2 .CC XS282S(12-678-4) 244/252@.50 .520/.540 lift
383 stroker with forged flat-tops (10.3:1 cr)
Steel crank/rods
AFR 210 Heads as cast w/ 2.08/1.6
1.6 Roller tip rocker arms
750 cfm Speed demon mech seconds w/RPM air gap intake
Stock HEI w/pertronix kit
8 mm plug wires
1 3/4 headers and 3" collectors
windage tray
7 qt baffled oil pan
will spray 100-300 hp
Steel crank/rods
8 mm plug wires
windage tray
