Just install my B&M holeshot 2400 stall converter on a TH350 tranny. Here is the problem I had. The converter came with 3/8-16 by 1/2" length mounting bolts. When installing them through the flexplate into the converter they only catch about 2 threads and I could feel them staring to strip as I was torquing them to 30 ft. lbs. It really needed a 3/8-16 x 5/8" mounting bolt to fit properly but I could not find any 5/8" length bolts at ACE except in stainless steel. the next size was 3/4" length and they bottom out before being able to tighten them properly. What I did was use a 3/8-16 x 3/4" grade 8 bolt with 2 grade 8 washers. This was they did not bottom out and they do not seem to stick out to far to have clearance issues. I use loctite also. Do you think this will be a problem or should it work OK? Thanks
